2001 Ford Escort Battery Warning Lamp
2001 FORD ESCORT
196,000 MILES • 4 CYL • FWD • AUTOMATIC
AEGISGAUGE
Hopefully this is an easy one. My car's battery light on the dash flickers when I drive around 50-70mph. I noticed that when the headlights are turned ON, the battery light will not flicker at all but when I turn them back OFF, it will flicker again between 50-70mph. Once I pressed the accelerator pedal a little hard while on a highway and the battery light went solid and I had to pull over and restart the car to make it go out. I tried leaving the car in Park and revving the engine and the battery light will still flicker at high rpms. What's going on?
Email me at: tntdrummer@yahoo.com if you care to help. Thanks
Nov 1, 2010 at 4:43 PM
BLUELIGHTNIN6
  • 16,542 POSTS
you will want to have the charging system tested . this includes the battery, battery cables and connectors, alternator and alternator drive belt. your local auto part stores usually test batteries and alternators for free.
Nov 1, 2010 at 5:12 PM
AEGISGAUGE
So any idea of what's going on then? The Alternator was replaced with a refurbished about 3 years ago and the battery was just replaced a month ago.
Nov 2, 2010 at 3:41 AM
BLUELIGHTNIN6
  • 16,542 POSTS
seems like an alternator issue but it's possible that it's the drive belt and not the actual alternator itself
Nov 3, 2010 at 11:23 AM
AEGISGAUGE
Yeah I agree. I figure the belt might be worn and slipping occasionally or the battery cables are defective or the brushes in the alternator acting up. It's just wierd that when the headlights are on, I can drive any speed without the battery light coming on.
Nov 4, 2010 at 1:32 AM
