2000 Ford Escort wierd noise
86,000 MILES • 4 CYL • FWD • MANUAL
SHAWNBOY13
im hearing a strange noise when i am slowing down and pressing the brake, its coming from the rear left tire area. i just recently replaced the drums and shoes, spring, parking brake cables ect. Im not sure if its a bearing or something, can you help?
Sep 14, 2010 at 5:47 AM
  • 110,248 POSTS
Can you describe the noise? Does it change when turning? Also, have you checked to make sure nothing has come apart in the brake drum?
Sep 14, 2010 at 1:21 PM
SHAWNBOY13
the noise sounds like a clunking/ knocking noise, it only can be heard when i press the brake pedal, even when i use the parking brake it still make the noise when slowing down, i have checked and everything is ok, it seems like the drum and shoes are not having the correct contact and I dont know why
Sep 14, 2010 at 1:28 PM
  • 110,248 POSTS
Did you properly adjust the rear brakes? Are you sure the drums are not out of round? That is what it sounds like. They may need cut.
Sep 14, 2010 at 1:50 PM
SHAWNBOY13
well it sounds like the noise is only coming from the drivers side rear tire area, when i changed the shoes the wheel cylinder piston did come out with the shoe and i had the brake system bled but im not sure if that damaged the cylinder, im fairly sure the brakes are adjusted properly
Sep 14, 2010 at 2:02 PM
  • 110,248 POSTS
If it is a knocking sound (even with the park brake) I believe the drums are out of round. I would have them checked and cut if possible.
Let me know what you find. As far as the wheel cylender, if there are no leaks, it is fine.
Sep 14, 2010 at 11:23 PM
SHAWNBOY13
the wheel cylinder does not leak at all
Sep 14, 2010 at 11:39 PM
