2000 Ford Escort want start all it do is turn over
2000 FORD ESCORT
12,311 MILES • 4 CYL • FWD • MANUAL
TONY31605
all it do is turn over but want start
Feb 20, 2010 at 1:52 PM
Do below maybe something will show up is to why
Get a helper disconnect a sparkplug wire or 2 and ground it to the engine atleast 3/16 away from ground-have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs,coil's resistances,distributor pick-up coil, ignition control module, cam and crank sensors and computer Note: If it doesn't apply disregard it
Feb 20, 2010 at 2:14 PM
