2000 Ford Escort Very rough running
BARRYPARSONS
Engine Performance problem
2000 Ford Escort 4 cyl Front Wheel Drive Automatic
My problem on my 2000 escort started out as a rough idle when the car was cold, and every so often it would just start running rough for a few minutes after iy was warmed up. Now it won't hardly stay running at all. I have checked for spark (good) replaced to coil pack, the fuel filter, and the camshaft position sensor with no luck. I just removed the cat converter thinking that had to be the problem, and it will idle a little pretty good now, but runs terribly rough when given any gas at all. If I pull the fuel line from the filter, and hit the key, it will shoot fuel about a foot in the air, so I'm assuming I have plenty of pressure. Any help would be greatly appreciated.
Aug 26, 2009 at 9:27 AM
LAZYGAZER
  • 68 POSTS
check the plugs and see their condition if they are wet see if its oil or water. also check for color. Update us.
Aug 26, 2009 at 3:58 PM
BARRYPARSONS
I pulled the plugs, they looked to be in real good shape, no oil or discoloration and they "appeared" t ohave good spark when I grounded them out and hit the starter
Aug 27, 2009 at 1:45 AM
2CARPRO JACK
  • 11,533 POSTS
Are they all the same color? You are looking fo rone or more that are white compared to the others.If this is a 1.9 single cam, you may want to do a compression test to be sure the engine is good.I have seen many of those lose the valve seats in the head and run really rough
Aug 28, 2009 at 12:42 AM
BARRYPARSONS
Yes, they are all the same color. I FINALLY realized, when I changed the fuel filter, there wasn't any gas spraying from pressure, so I'm in the process of replacing the fuel pump. I'll keep you posted
Sep 1, 2009 at 5:36 AM
