2000 Ford Escort valve cover gasket
125,698 MILES • 4 CYL • 2WD • AUTOMATIC
BARTOND
I was wandering how to change the valve cover gasket in my 2000 ford escort.
Jul 24, 2008 at 6:02 AM
BMRFIXIT
  • 19,053 POSTS
Disconnect negative battery cable. Loosen, but DO NOT remove upper timing belt cover. Disconnect spark plug wires from spark plugs by slightly twisting and pulling off in a straight direction from spark plug,. Detach crankcase ventilation hose. Remove valve cover bolts by loosening diagonally, starting with bolts located on outside edge of valve cover, working inward
Jul 27, 2008 at 1:04 PM
