2000 Ford Escort Transmission slips
2000 FORD ESCORT
131,000 MILES • 4 CYL • FWD • AUTOMATIC
BROOMS321
The transmission seems to slip just a little in first but works good in 2nd,3rd,and over drive. Reverse work well also. Does the transmission have any adjustments to help the slipping in first or / band adjhustments? If I need the transmission fixed what could it cost me?
Thanks
Steve
Nov 7, 2010 at 7:10 AM
  • 110,244 POSTS
Does it slip in reverse? The clutch pack for first gear is also used for reverse.
Nov 8, 2010 at 12:08 AM
BROOMS321
Only slips i 1st a little reverse works fine,
Thanks
Steve
Nov 8, 2010 at 3:44 AM
  • 110,244 POSTS
I would have trans pressure tested. The same clutch pack works low and reverse. If the pressure is low, it may not be fully engaging 1st gear. Also, make sure the trans fluid is full and clean.
Nov 8, 2010 at 4:48 AM
