Recently my "service engine soon" light came on. I went to an auto parts store and they checked out the compter and it said that the cooling sensor switch needs replaced. I got the part and had my friend to help me because I didn't want to screw up anything. The only sensor that we can find is the one mounted directly onto the water pump. Is this the correct spot because it does not fix the hole there. Can you help me out with where the sensor is located. ?
Mar 5, 2009 at 6:20 AM
