2000 Ford Escort Smoking
2000 FORD ESCORT
50,000 MILES • 4 CYL • FWD • AUTOMATIC
MIKEINBROOKLYN
I drove my car up from Florida to NY in Oct. Took it to Jiffy Lube on Dec. 19th to 'winterize' , flush the radiator and add the 50/50 antifreeze. Ever since then my car is smoking. at first I thought so coolant dripped ..no big deal. Two weeks later it is still smoking...what could be the problem.
Jiffy lube seem to think the radiator has a leak and for $50 he can get me a radiator from a junkard in the 'bronx'
Meanwhile prior going to Jiffy Lube my car NEVER smoked.
Dec 30, 2009 at 1:54 AM
OBXAUTOMEDIC
  • 3,711 POSTS
Have you check the coolant level?
If low then you possibly have a leak. You may be able to locate the leak yourself. Just warm engine up operating temp make sure system is pressurized, you can carefully using a towel or rag squeeze the upper radiator hose if hard to squeeze then system is pressurized. Then just look around for any coolant spraying. If still cannot find a leak may need to have a shop pressure test system.
Also, is there an order to the smoke. Another possibility is an oil leak. Check valve cover gasket.
Dec 30, 2009 at 2:15 AM
