2000 Ford Escort shifting the gear
2000 FORD ESCORT
85,000 MILES • V8 • 2WD • AUTOMATIC
OTISBURNS
I can not shift my gear from park to drive. It become lock in place when i go back to park. and the only way i can down shift is to turn the ignition to the off position and slid the gear to neutral and crank the car.Brake lights want work. I dont know, but i believe that these two problems are related. thank you
Sep 30, 2008 at 12:38 AM
BMRFIXIT
  • 19,053 POSTS
Check fuses and check brake light switch on top of the brake switch
good luck
need manual CHECK IT @
https://www.2carpros.com/kpages/auto_repair_manuals.htm
Sep 30, 2008 at 10:59 AM
OTISBURNS
brake swicth and brake light switch, where are they located !
Oct 1, 2008 at 5:06 AM
BMRFIXIT
  • 19,053 POSTS
on top brake paddl e
good luck
https://www.2carpros.com/kpages/auto_repair_manuals.htm[/quote]
Oct 1, 2008 at 11:03 PM
