2000 Ford Escort shakes
2000 FORD ESCORT
FULLHOUSE417
Shakes or Wobbles problem
2000 Ford Escort 4 cyl Front Wheel Drive Automatic
I PUT NEW TRANSMISSION MOUNTS IN BECAUSE THE ONE IN THE FRONT WAS BROKEN NOW IT VIBRATES WHEN YOU PUT IN GEAR BADLY ALSO STALLS IS TRANSMISSION BAD? WHAT WOULD YOU RECOMEND?
Dec 4, 2009 at 8:20 PM
STACIETHESTRANGE
I was having the same problem with my escort a few months ago. I was worried the vibration indicated a critical problem with the tranny, but it ended up being a bad tie rod. The part was only $20 and when I replaced it, the vibrations dissipated. I would recommend checking the front ball joints and tie rods if you're still having troubles.
Dec 24, 2009 at 4:11 AM
