2000 Ford Escort PLEASE RESPOND
JACQUELINE1980
Other Category problem
2000 Ford Escort 4 cyl Wheel Drive Type unknown Automatic 126000 miles
MY CAR IS A 2000 FORD ESCORT ZX2 AND WHEN IT SITS STILL AND WHEN YOU PUT IT IN PARK IT WANTS TO SHUT OFF AND IT ALSO IS IDILING REAL HIGH WHAT IS THE PROBLEM?
Feb 12, 2008 at 4:44 PM
2CARPRO JACK
  • 11,533 POSTS
Look for a big vacuum leak.Follow th epcv lint to the intake and be sure the rubber grommet is good.If need be carefully spray the vacuum lines and intake area with carb cleaner, when the engine idle changes, you have found a leak.
Feb 12, 2008 at 11:36 PM
