2000 Ford Escort misfiring
2000 FORD ESCORT
TODD PORTER
Engine Performance problem
2000 Ford Escort 4 cyl Front Wheel Drive Automatic
I've been helping my son in law repair his 2000 escort zx2. It has a bad misfire at idle, when driving it will barely go faster than 20-25 mph. We replaced the plugs, wires and ignition pack with no positive results. I've looked online and see this could be a common problem with these cars, but I've never seen a solution posted on the various message boards. I really don't want to try the trial and error method as it can be expensive with no positive results, and we aren't rich. Please advise.
Sep 21, 2008 at 2:01 PM
BMRFIXIT
  • 19,053 POSTS
Well you need to determine which cylinder that is misfiring
you can do so by scanning for codes
have a compression test on that cylinder
check injector too
check exhaust back pressure
Sep 21, 2008 at 2:15 PM
