2000 Ford Escort IGNITION
132,200 MILES • 4 CYL • 2WD • MANUAL
DAVIDOLSON727
GOING TO U PULL IT TODAY FOR NEW IGNITION WHATS THE RANGE OF YEAR CARS THAT I CAN GET ONE OFF OF
Sep 30, 2010 at 3:01 AM
MERLIN2021
  • 17,250 POSTS
Any junk yard you go to will have a crossover book to let you know what parts are interchangeable. What parts do you need?
Sep 30, 2010 at 4:20 AM
DAVIDOLSON727
[quote="DAVIDOLSON727"]Steering problem
2000 Ford Escort 4 cyl Two Wheel Drive Manual 132200 miles
GOING TO U PULL IT TODAY FOR NEW IGNITION WHATS THE RANGE OF YEAR CARS THAT I CAN GET ONE OFF OF[/ REPLACEING SWWITCH
quote]
Sep 30, 2010 at 4:46 AM
MERLIN2021
  • 17,250 POSTS
You replacing the switch, or the key cylinder? The switch is better if a NEW part is used, actually it's better for either one, but if you are replacing the key and cylinder, Ford will need to program it for you. Different transponder chip than in your key, will not work unless it's reprogrammed.
Sep 30, 2010 at 3:58 PM
