2000 Ford Escort Gas Hand won't move
TNALLS
Computer problem
2000 Ford Escort 4 cyl Front Wheel Drive Automatic
My gas hand won't move off of Full and the prevents the gas light from coming on and i replaced the fuel sending unit and the fuel pump what's wrong
Jun 10, 2008 at 12:13 PM
BMRFIXIT
  • 19,053 POSTS
Turn ignition off disconnect fuel level sensor /fuel pump connector measure resistance between ground and fuel level sensor harness connector terminal #2(black wire)
resistance should be less than 5ohms
if more than 5 repair in black wire
if 5 or less check the instrument cluster
Ask an automotive repair question!
https://www.2carpros.com/affiliate/uid/bmrfixit_1_tlid_1
Jun 10, 2008 at 1:56 PM
