2000 Ford Escort engine not starting.
MHORTON1990
2000 Ford Escort Automatic
My engine won't start. I turned the key but heard nothing and it didn't turn on. We thought it was the battery because my brake lights would turn on by themselves while i was at work or at home. I didn't think that could be the cause. when we changed the battery for a new on and tried to start it we got the same results. Nothing. Not even the noise it usually makes.
Mar 16, 2010 at 9:36 AM
  • 75,988 POSTS
No crank at all/nothing/nada:
Could be the starter, starter relay, clutch switch/park and neutral switch and ignition switch assuming the battery and connections are good.
Mar 16, 2010 at 10:41 AM
