2000 Ford Escort CAR TEMP
PRADEEPSILL
Engine Mechanical problem
2000 Ford Escort Two Wheel Drive Manual 20 miles
HI ,
I want a clarification that , the car temperature should be in normal r it should be in cool at the very fast starting time in the morrning......
One of my mechanic s saying the temperature should be in normal while starting in the morning itself , but my car always in cool temp at the morning after running of 10 r 15 KM only it coming to normal temp , its any problem in my car r what Plz clarify mr doudt
Mar 21, 2009 at 3:25 PM
  • 75,988 POSTS
Try telling your mechanic to replace the thermostat-its job is to control engine temperature then the coolant temperature sensor reads it and sends it to the computer for other purposes. T
Also check if it has an engine temperature gauge switch-could be out of range
Mar 21, 2009 at 3:38 PM
PRADEEPSILL
i want to get clarify that in the first start itself the car temp should be in normal are it should be in cool , later for 5 r 10 km it want to be raise in normal r what ?
what the initial stage of the temp should be in the early morning ?
Mar 21, 2009 at 5:56 PM
  • 75,988 POSTS
Its should be in the cool area till the thermostat opens up and then it will level off at normal
Mar 21, 2009 at 6:45 PM
PRADEEPSILL
Hi ,
I have planned to buy 2nd FORD Fusion , is that a good plan r what need u r Advice , otherwise give some suggestion for any Diesel car
Mar 21, 2009 at 8:19 PM
