2000 Ford Escort 2000 Ford Escort ZX2 P0715 code
2000 FORD ESCORT
KENDU90
  • 20 POSTS
Transmission problem
2000 Ford Escort Two Wheel Drive Automatic 115000 miles
Today I was driving my fiance's car and the Check Engine Light came on. I had it read immediately and the code came up P0715 Transmission Input Speed Sensor: Circuit Malfunction. How much do you think it will cost to repair this issue? Actually, how much labor is involved? I'm sure the sensor is not that expensive. And finally, how safe is it to continue to drive this car? She has complained of the car lurching forward at times.
Thanks in advance for any help.
Jun 30, 2008 at 4:15 PM
SERVICE WRITER
  • 9,123 POSTS
I recommend having it tested to be sure it's bad. IF so, the part is probably around $115.00 and the labor should be about a half to three-quarts of an hour to change. IT is located under the battery tray.
Jul 1, 2008 at 12:19 AM
