If fuel pump is coming on then I wouldn’t be looking for a relay or any other component in relation to fuel
and you should check the fuel pressure
also no mention of the spark or if you had checked it or not I would do that as a 1st step
check crank sensor
make sure the timing belt is OK
SPONSORED LINKS
Tuesday, February 12th, 2008 AT 8:19 PM
