1999 Ford Escort Which tires to buy first?
1999 FORD ESCORT
JOSH7890
Tires and Wheels problem
1999 Ford Escort Automatic 200000 miles
I'm in Ontario, Canada, and winter weather is soon approaching. I have a set of 3 winter tires (Bridgestone Blizzak P185/65R14, about 5 years old) on my car now, with an old, nearly worn-out all-season tire on a rear wheel. I obviously need to get a replacement winter tire to complete the set, and I also need to get a set of all-season tires (unless I can use the winter tires all year round?).
The reason for the currently-mismatched tires is that one of the winter tires was badly punctured and couldn't be repaired.
A problem I've been having with both these winter tires and the all-season tires I was previously using is frequent flat tires. I've had a tire run flat almost every second month or so, but the auto shops never find any major problems with the tires and have been re-sealing the bead or replacing the valve stem.
Is it possible that we need new rims? Since I've had frequent flats with two different sets of tires, I wonder if the rims are a possible cause.
Is there anything else I should consider?
I don't plan on keeping the car longer than 4-5 years.
Oct 3, 2009 at 11:09 AM
