1999 Ford Escort water sprays out
CMP0410
Engine Cooling problem
1999 Ford Escort 6 cyl Front Wheel Drive Automatic
If it is the freeze plug!
do they need to lift engine or transmission?
How expensive on average to replace freeze plug.
Apr 1, 2009 at 12:59 AM
BMRFIXIT
  • 19,053 POSTS
Need to locate the leak 1st
where is it coming from you have freeze plugs all over the engine
pressure check coolant system as a 1st step and locate the leak than let me know
Apr 2, 2009 at 1:54 PM
