1999 Ford Escort transmission lines
78,000 MILES • 4 CYL • FWD • AUTOMATIC
BILLOWEYES
i have a transmission leak. someone said that its my trnas lines that are located in front of radiator that are rusted out and need to be replaced. can i get this part from an auto parts store or just a ford dealer? also how much would this cost to repair?
May 2, 2008 at 9:47 AM
MUSTANG87
  • 261 POSTS
you need to make sure where the leak is.look under the car trans pan for leaks then follow th trans lines looking for leaks and if one or 2 lines r leaking radiator try adjusting them tighten them up but dont over do it .also u can use plumber tape on lines so it can be better and not leak.
May 2, 2008 at 5:12 PM
