1999 Ford Escort The Glow light on the Gear Panel stopped w
1999 FORD ESCORT
42,000 MILES • 4 CYL • 2WD • AUTOMATIC
ANMOL
Hi All:
the lights on the gear panel stopped working sometime last week; it is very inconvenient to work gears without those lights. Is there a quick fix?
Thanks in advance, anmol.
Sep 30, 2008 at 11:25 AM
BMRFIXIT
  • 19,053 POSTS
Its a light bulb and it needs to be replaced.
Sep 30, 2008 at 1:17 PM
ANMOL
Can it be replaced easily? At pep boys or somewhere....maybe myself?
Thanks.
Sep 30, 2008 at 1:20 PM
BMRFIXIT
  • 19,053 POSTS
Its not to bad you can try your self
if not sure, your local shop can do it
good luck
need manual CHECK IT @
https://www.2carpros.com/kpages/auto_repair_manuals.htm
Sep 30, 2008 at 1:33 PM
