1999 Ford Escort The cooling fan continues to run after ign
1999 FORD ESCORT
99,000 MILES • 4 CYL • 2WD • AUTOMATIC
KLEMASTER
I have a 1999 Ford Escort and the cooling fan keeps running after the ignition is turned off. I have changed the Cooling Fan Module (two different ones from the junk yard first one didn't change anything so I thought it may be bad and got a different one) and the fan is still running when the ignition is off. While the engine is off and the cooling fan is still running I have disconnected the coolant temperature sensor and the fan keeps running. Is there anything else it could be?
Apr 5, 2010 at 9:53 AM
BLUELIGHTNIN6
  • 16,542 POSTS
check for faulty cooling fan relay(s).
Apr 5, 2010 at 10:16 AM
