1999 Ford Escort Speedometer not working
1999 FORD ESCORT
86,300 MILES • 4 CYL • 2WD • AUTOMATIC
THOM0101
My check engine came on, giving the code for faulty EGR valve. After disconnection, of the OBDII, my speedometer quit working. I then got a code for a vehicle speed sensor. I replaced both the EGR valve and the speed sensor. The speedo still does not work, however when I plug the OBDII into the recepticle as if testing, the speedometer operates. What could be going wrong?
Mar 13, 2010 at 9:16 AM
DAVE H
  • 13,384 POSTS
you will need to have the PCM checked ?
Mar 15, 2010 at 2:44 AM
