1999 Ford Escort Sensor
163,000 MILES • 4 CYL • FWD • AUTOMATIC
EDGARCIA8900
IS there a sensor located anywhere that tells the trans when to shift, for the most part the car runs fine. every once in awhile @ cruising speed ot downshifts out of overdrive and doest want to go back. Thank you
Mar 3, 2009 at 6:07 AM
  • 75,988 POSTS
There's a transmission control module or the main computer that tells the transmission how to operate properly thru shifting solenoids, TPS and VSS sensors-
Mar 3, 2009 at 6:16 AM
EDGARCIA8900
[quote:f00238ba01="rasmataz"]There's a transmission control module or the main computer that tells the transmission how to operate properly thru shifting solenoids, TPS and VSS sensors-[/quote:f00238ba01]
Thank you car codee tps , I replaced running great. Thanks again
Mar 6, 2009 at 12:49 PM
