1999 Ford Escort problems starting car
19,800 MILES • 4 CYL • FWD • AUTOMATIC
COWBOYDON
When i put the key in the ignition i have to play with it for 30 minutes or more before it starts do you have a clue what it could be??
Jun 29, 2010 at 1:03 PM
  • 75,988 POSTS
If its not cranking, doing nothing at all and the lites you normally see when you turn key to run-Check and Test below
Could be the starter, starter relay, clutch switch/park and neutral switch and ignition switch assuming the battery and connections are good.
Jun 29, 2010 at 9:20 PM
