1999 Ford Escort Oxygen sensor and light on
1999 FORD ESCORT
CHRISYAM2010
Electrical problem
1999 Ford Escort 4 cyl Two Wheel Drive Automatic 154k miles
my check engine light is on, when i connect the scanner it says that I have a mal function in sensor one bank one. I changed the o2 sensor before the cat converter two time already and the light hasnt turned off. what can it be?
Apr 2, 2010 at 4:28 PM
BLUELIGHTNIN6
  • 16,542 POSTS
you have to delete the trouble codes with the scanner, it will not turn off on its own.
Apr 2, 2010 at 5:08 PM
CHRISYAM2010
[quote="chrisyam2010"]Electrical problem
well actually i have tried that and nothing works, it is something in the sensor! I have deleted the codes 3 times already and it keeps coming up. if i have changed the o2 sensor and that is not the problem then what it is? can you help me with this?
Apr 3, 2010 at 3:35 PM
BLUELIGHTNIN6
  • 16,542 POSTS
if you have deleted the code and it comes back then most likely the cat. converter is faulty. a bad converter will cause the oxygen sensor fault code to appear.
Apr 4, 2010 at 8:36 AM
