1999 Ford Escort on heat
86,000 MILES • 4 CYL • 2WD • AUTOMATIC
GEORGERJM
i have no heat fan is good o2 sensor is ok engine temp.is right.
Jan 30, 2010 at 5:54 AM
  • 75,988 POSTS
Check the thermostat could be stuck open and the heater core if its clogged-up to include the heater control valve if it has one also check coolant level
Jan 30, 2010 at 7:58 AM
