i have no heat fan is good o2 sensor is ok engine temp.is right.
Jan 30, 2010 at 5:54 AM
✓Experienced Mechanic
Check the thermostat could be stuck open and the heater core if its clogged-up to include the heater control valve if it has one also check coolant level
