1999 Ford Escort not working
154,000 MILES • 4 CYL • FWD • AUTOMATIC
ALBERTA41
Turning over but no fire, replaced the coil pack, relay on the side of the coil. Now What?
Jan 3, 2008 at 2:13 AM
ARTMANG
  • 61 POSTS
ignition control module
Jan 4, 2008 at 12:51 PM
CRAIGFL
  • 89 POSTS
You also need to be sure the timing belt is OK buy peeking under the cover at the top while the engine is being cranked. If it's broken or stripped teeth, the engine sound almost right while cranking but never starts...
Jan 4, 2008 at 11:24 PM
