1999 Ford Escort My escort will not go faster than 60k?
1999 FORD ESCORT
110,000 MILES • 4 CYL • FWD • AUTOMATIC
MAVERICKJASON
What could be the problem with my 1999 ford escort? It will not go above 60k. Seems like there is no power at all? It will not go any faster than 60k. Any ideas? Would it be a plugged catalytic converter?
Mar 5, 2010 at 3:43 AM
Inspect and test all the following listed below and get back with some results
Oxygen sensor.
Catalytic converter.
Fuel injectors dirty/sticking.
Mass airflow sensor/Airflow meter.
Throttle position sensor.
Manifold absolute pressure sensor.
EGR Valve
Fuel pressure regulator leaking or defective fuel pump.
False air leakage.
Fuel contamination.
Foul/defective spark plugs.
Open spark plug wires.
Ignition coil/Coil packs defective.
Incorrect ignition timing.
Cap and rotor.
Mar 5, 2010 at 4:21 AM
