1999 Ford Escort Missing and Skipping
138,000 MILES • 4 CYL • FWD • AUTOMATIC
WILLIAM PENN 09
I have had the Idle Air Control replaced and the fuel filter replaced, and the car still misses and skips> What should check next?
Thanks for your help
Mar 3, 2009 at 6:01 AM
  • 75,988 POSTS
Could be caused by the following:
Dirty fuel injectors (cleaning the injectors often fixes this).
Bad MAP (manifold absolute pressure) sensor
Bad TPS (throttle position) sensor
Bad or dirty MAF (mass airflow) sensor
Low fuel pressure (leaky fuel pressure regulator or weak fuel pump)
Vacuum leaks (intake manifold, vacuum hoses, throttle body, EGR valve)
Bad gasoline (fuel contaminated with water or too much alcohol)
Sometimes, what feels like a hesitation is actually ignition misfire rather than lean misfire. The causes of ignition misfire may include:
Dirty or worn spark plugs
Bad plug wires
Weak ignition coil
Wet plug wires
Mar 3, 2009 at 6:05 AM
