1999 Ford Escort low oil pressure
1999 FORD ESCORT
145,000 MILES • 4 CYL • 2WD • AUTOMATIC
LYNWORTH
I put my car up on ramps and tried to drain some of the engine coolant from a little valve. After doing that and adding some water and coolant, I took it for about a 3 mile drive. I heard some chattering and when I pulled it back in the driveway, my "service engine soon" and "low oil pressure" lights came on. Could I have somehow clogged my oil pump when it was on ramps? I have no idea how this happened. Thanks. I promise I will donate if you guys help me fix this.
Oct 29, 2008 at 8:06 AM
Hi lynworth and welcome to 2carpros
Scan the computer for OBD2 code/s and comeback with it-also check the oil level-is your coolant level in the full mark in the reservoir bottle when engine cools off if not fill it-could be overheating causing it to detonate the noise that you hearing
Oct 29, 2008 at 8:16 AM
LYNWORTH
nevermind...i believe it is a blown head gasket. i'm seeing vapor and oil from the exhaust.
Oct 29, 2008 at 9:29 AM
