Can you tell me where the fuel system fuse, the relay, and the inertia switch are located. It is a station wagon.
Feb 13, 2009 at 2:17 AM
BILLYMAC
✓Experienced Mechanic
hi inertia switch pass side kick panel where the pass right leg would be. fuel relay underhood near the batt green bottom relay is fuel brwn is eec relay.fuse is in relay cntr. billymac
Feb 13, 2009 at 7:56 AM
