1999 Ford Escort Front Wheel Bearings Ford Escort 1999
175,000 MILES • 4 CYL • 2WD • MANUAL
ASUSPENCER
I would consider myself able to do all mechanical repairs unless it requires some special tools. My question is if I would be able to change the front wheel bearings myself and if not so how much it should cost me for one to be done.
Oct 8, 2010 at 5:06 AM
SATURNTECH9
  • 30,869 POSTS
The front wheel bearing are pressed in there not a complete hub assembly if you had a front wheel bearing remover it wouldn't be so bad otherwise you would have to remove the whole knuckle and have everything pressed out.DO you have only one bad or are both making noise?Do you know how to tell which one is bad?
Oct 8, 2010 at 5:22 AM
ASUSPENCER
I am 100% certain that it is the front left. After asking around i realized a local auto parts store will let me borrow a front wheel bearing remover. I think I should be able to do it fairly easily if that is really the only special tool required. Or do I NEED a press to put the new wheel bearing in?
Oct 8, 2010 at 7:35 AM
SATURNTECH9
  • 30,869 POSTS
It depends on which wheel bearing remover they have you might need a slide hammer and a hub puller attachment to remove the hub from the bearing.
Oct 8, 2010 at 7:40 AM
ASUSPENCER
Ok I havent had a chance to work on this for awhile but i am stuck now. I am unable to remove the hub. I have the hub puller yet it is not able to do the trick. Is there any special things i have to do to remove the hub?
Oct 16, 2010 at 8:31 AM
SATURNTECH9
  • 30,869 POSTS
What kind of hub puller are you using?Tell me the make and model so i can see which one your using.
Oct 16, 2010 at 1:06 PM
