1992 Ford Escort Front Wheel bearing
777999YES
  • 1992 FORD ESCORT
  • 4 CYL
  • MANUAL
  • 20,700 MILES
I want to grease my front wheel bearings, I have the proper socket for the large nut to remove it, but it does not seem to move, seems there is a small indention keeping the large nut from moving, is it a stop to prevent the large nut from moving? How can I remove this large nut and get to the bearing. Thanks, Richard
Wednesday, September 16th, 2009 AT 5:07 PM
BLUELIGHTNIN6
  • 16,542 POSTS
To remove wheel bearing you must remove the hub & steering knuckle assembly. Procedures are below..
https://www.2carpros.com/forum/automotive_pictures/261618_Noname_975.jpg
https://www.2carpros.com/forum/automotive_pictures/261618_Noname2_272.jpg
Wednesday, September 16th, 2009 AT 9:11 PM
777999YES
THANKS VERY MUCH, I THOUGHT THIS COMPUTER HAD SOME IMPORTANT PEOPLE USING IT, I WILL NOW GO TO WORK ON MY LITTLE CAR, THANKS AGAIN AND AGAIN, IF YOU NEED ANY INFO EITHER ON THE BIBLE OR ELECTRIC OR PLUMBING QUESTIONS, I WILL HELP YOU WITH ANSWERS, BLESSINGS TO YOU ALL, RICHARD ---209-887-3524--
Thursday, September 17th, 2009 AT 10:41 AM
