1999 Ford Escort Front brake caliper
105,947 MILES • 4 CYL • 2WD • AUTOMATIC
RONJJ22
  • 9 POSTS
I have replaced the fornt brake pads and rotors on my vehicle. I have recently noticed a burning smell coming from the left front wheel. I removed the wheel and noticed that the rotor was very hot and there was very little clearance between the brake pads and the rotor. I am planning to replace the brake caliper. Do you have any instructions on the proper procedure for this? Or is the problem something else?
Mar 10, 2009 at 1:28 AM
DOCFIXIT
  • 18,828 POSTS
Nope just frozen caliper due to dirt getting past boot and when you retracted piston the dirt went into chamber the siezed piston to bore.
Mar 10, 2009 at 6:15 AM
RONJJ22
  • 9 POSTS
Thanks for your reply. How can I resolve the situation?
Mar 10, 2009 at 6:43 AM
DOCFIXIT
  • 18,828 POSTS
Replace caliper with rebuilt unit. @$40
Mar 10, 2009 at 6:54 AM
RONJJ22
  • 9 POSTS
Do you have a diagram or instructions on how to do this to assist me? Thanks in advance
Mar 12, 2009 at 8:26 AM
DOCFIXIT
  • 18,828 POSTS
Take off caliper as you did when replacing pads but before removing caliper break loose hose. When calipis off rotate off hose. Do not reuse copper washer.Install in reverse order then bleed system.
Mar 12, 2009 at 8:33 AM
