1999 Ford Escort ford escort problems
MBANSE
1999 Ford Escort
I just got back from a long drive when my car started to overheat. I changed the thermostat and it seemed to do the trick. Now just a few hours later, my car is starting to kill when I slow down to a close stop. Any suggestions as to what is wrong?
Nov 4, 2008 at 10:49 AM
BMRFIXIT
  • 19,053 POSTS
Recheck your work
make sure all connected back
check for vacuum leaks
clean and check idle air control valve
check for codes if possible
did u had to disconnect the battery and if so pcm need to relearn idle position
need manual CHECK IT @
https://www.2carpros.com/kpages/auto_repair_manuals.htm
Nov 4, 2008 at 11:20 AM
