I was hoping to get an estimate on the clutch. any help would be appreciated.
Dec 6, 2007 at 1:27 AM
JWALTH02
MEMBER
Buying just the clutch or do you want the estimated installed price? The first is around 150-200 depending where you go, and the second you would be better off calling multiple shops in your area that will install them. If you have a Tanner Transmission anywhere around you I highly recommend them. Good Luck!
