1999 Ford Escort Escort ZX2
92,066 MILES • 4 CYL • FWD • AUTOMATIC
RESCOBAR327
  • 6 POSTS
How do I check for spark, fuel pressure and injector pulse on an 1999 Escort ZX2
Jan 28, 2008 at 8:37 AM
BMRFIXIT
  • 19,053 POSTS
[quote:ac0f1cc522="rescobar327"]1999 Ford Escort 4 cyl Front Wheel Drive Automatic 92066 miles
How do I check for spark, fuel pressure and injector pulse on an 1999 Escort ZX2[/quote:ac0f1cc522]
Check for spark
: pull off one spark plug wire off the plug
place it near ground (metal around the engine )
ask helper to crank the engine for you watch for arcing between the wire and the ground
or the safe way , you can get a spark tester and place it between the wire and the spark plug and watch it glow when cranking if you have spark
you need a fuel pressure tester gauge to check the fuel
also u need a bulb to check for injector pulse
pull wire connector off injector place bulb tester in and crank if light on off you r good
CHECK TIMING BELT
Jan 28, 2008 at 11:11 AM
