1999 Ford Escort ENGINE IGNITION COIL
1999 FORD ESCORT
150,000 MILES • 4 CYL • 2WD • AUTOMATIC
LOSJAVIS
HI I HAVE A PROBLEM W/ A FORD ESCORT DONT START, I CHECK THE FUEL , IT IS OK. BUT I FOUND THE IGNITION COIL PACK DONT SEND POWER TO THE WIRES WHAT COUL BE THE PROBLEM TO DONT SEND POWER THRU THE SPARK WIRES IF GETS POWER FROM THE FUSE BOX?
Feb 18, 2010 at 7:30 AM
BMRFIXIT
  • 19,053 POSTS
Check timing belt
Check for codes
Suspect crank sensor
Or ignition coil
Feb 19, 2010 at 12:50 PM
