1999 Ford Escort coil pack fails to generate spark
1999 FORD ESCORT
110,100 MILES • 4 CYL • FWD • AUTOMATIC
CLACKER54
Ok to start I purchased this car from a police impound auction, now it has me scratching my head. What I have checked so far: Timing is correct, fuel pressure is good, Batery is Good, replaced fuel filter. I still have the same problem and that is the engine just spins no fire from coil pack (Checked with ignition tester or little spark plug thingy) there are tree wires going into the coil ohm meter says there is power to all three at different times Ie key on Key in start. I replaced the coil pack and capicitor with one from a running engine (same year model) with no sucess. from what I can tell one wire takes power from the ignitions switch and the other two go to the eec are there any fusable links or relays that I may have over looked? It has an auto matic transmission and I thought maby that might be the cause(neutral safty switch) however the wiring diagram that I have says the safty switch goes to the eec. if the problem was there the eec should be sending a code. Which there are none according to my code reader. Help!!!
Mar 31, 2009 at 11:52 AM
BMRFIXIT
  • 19,053 POSTS
with key on do you have check engine light on ?
you should if not check fuses and relays
check and suspect crank sensor
let me know
Mar 31, 2009 at 3:04 PM
