1999 Ford Escort Car won't move
63,000 MILES • 4 CYL • 4WD • AUTOMATIC
NIESHI
My car stopped moving so I changed the transmission filter and transmission fluid. The car starts fine but, when I shift it into gear it would not move in any gear. what woould you suggest is the problem.
Jan 4, 2009 at 12:17 AM
2CARPRO JACK
  • 11,533 POSTS
If the fluid level is good and it doesnt move. Sounds like the trans is needing a rebuild. Check to be sure the axles are ok first though and that the shifter is working at the trans
Jan 4, 2009 at 12:44 AM
