1999 Ford Escort Brake lights remain on
133,000 MILES • 4 CYL • FWD • AUTOMATIC
RON WHITMAN
My brake lights - including the third light in the rear window remain on after shutting the car off. In order to get the lights to turn off I must remove the 15 amp fuse under the dash. In order to get the car in gear (it will start) I must replace the bulb before I can move the gear shift. The fuse appears to be in good shape. Thank you for any assistance you can render.
Apr 10, 2010 at 1:06 PM
  • 75,988 POSTS
Inspect and adjust the brake switch unable to replace it-
Apr 10, 2010 at 11:26 PM
