1999 Ford Escort blower motor wont work
ANDREWD81
Electrical problem
1999 Ford Escort 4 cyl Front Wheel Drive Automatic
i took the blower motor out an it works so i changed the switch that controls the speed of the motor still doesnt kick on an i checked all the fuses. what could it be
Apr 26, 2008 at 8:57 AM
BMRFIXIT
  • 19,053 POSTS
You need to check relay and power
you need to use a test light or volt meter
check for power at the blower motor
place switch at high
blue wire should have battery power
and black /blue should be ground
if ground present check blower motor resister
if no power check blower motor relay (relay box left side of dash near kick panel )
check wiring
Apr 26, 2008 at 9:46 AM
