1999 Ford Escort battery light flashing
SHOLEMAN
1999 Ford Escort 4 cyl Front Wheel Drive 72000 miles
My battery light was flashing, so I thought I needed a new battery so I purchased a new battery and installed it and the battery light flickers on every time I put my foot on the gas and goes off when I put my feet on the brake. What can this be.
Dec 24, 2009 at 1:46 AM
IMPALASS
  • 3,112 POSTS
Hello
To better assist you is your model the LX, SE, or ZX2 and what is the engine size in liter
Dec 24, 2009 at 2:18 AM
IMPALASS
  • 3,112 POSTS
Hello
One other thing I need you to do before you get back with me.
Please go to Auto Zone (AZ) or O'Reilly's (OR) and for FREE they can pull the codes to the car. Most important: Once they check your codes, if they find something and you don't get it fixed and need to get back with us, please make sure you tell us exactly what the code was, number and all. Example, if the code was E0568 O2 Sensor bad. Then make sure you give us all of that. While there for FREE also they can bring their tester out and check your battery and alternator. It is important they check out your alternator.
Dec 24, 2009 at 2:22 AM
