1999 Ford Escort answer to noise quest.
100,000 MILES • 4 CYL • FWD • AUTOMATIC
RAYMAN90744
In response to your noise question, I had the same problem not to long ago, a loud noise coming from the engine, and just as you said, at high RPM's it would go away. At first I thought it was the belt, but it wasnt, IT TURNED OUT TO BE A PCV VALVE on the front right side of the engine that was making the sqeeling noise. It cost a couple dollers to replace.
Mar 28, 2008 at 11:18 AM
BLACKOP555
  • 10,386 POSTS
thanks for the heads up, i have never experienced this myself, but will keep this in mind.
thanks again.
Mar 28, 2008 at 1:23 PM
