1999 Ford Escort alternator replacement
SCOTTYB3258
Electrical problem
1999 Ford Escort 4 cyl Two Wheel Drive Manual
My question is after i have removed the alternator and bought a new one how do i properly install it? Big question is how do i loosen and unloosen the belt?
Mar 6, 2009 at 3:06 AM
DAVE H
  • 13,383 POSTS
GENERATOR Removal & Installation Disconnect negative battery cable. Disengage drive belt from pulley. Remove power steering hose bracket from generator bracket. Remove generator mounting bolts. Remove generator. Disconnect wiring from generator. To install, reverse removal procedure. Tighten lower generator bolt to 15-22 ft. lbs. (20-30 N.m). Tighten upper generator bolt to 29-44 ft. lbs. (40-55 N.m).
https://images.2carpros.com/forum/automotive_pictures/266999_AAA2_6.png
Mar 6, 2009 at 3:31 AM
