1999 Ford Escort ABS LIGHT
164,000 MILES • 4 CYL • AWD • AUTOMATIC
DEEWA4RDESCRT
I had to drive my Escort through water that did not cover the tires or did not come up to my door and the ABS light came on. I was told when I got home to just let it sit maybe the sensor got wet. When I woke up the next morning to go to work, it was off. It stayed off for about 5 days. It came back on for a while today and now it is off again. Is there a way to check anything without going to the mechanic to see if it is just a sensor or something minor.
May 29, 2008 at 4:56 PM
  • 31,937 POSTS
Hi there,
You may have moisture affecting a loom plug. You should get a scan as this may tell you which sensor is acting up, you will need to clear the codes at the same time.
Mark (mhpautos)
May 29, 2008 at 5:08 PM
