my car run rough and when I decelerate or stop it give gas smell and want to stop though it keep running but it shake and run rough
Aug 28, 2009 at 10:56 AM
✓Experienced Mechanic
Could be running on the rich side due to the following: A bad O2 sensor, excessive fuel pressure (bad fuel pressure regulator or plugged return line), leaky fuel injectors, dirty air filter or restricted air inlet, or a defective coolant sensor that prevents the engine management system from going into closed loop mode.
